  • 5 Vote(s) - 3.2 Average
Dashboard back light
Hi all.
I am sure there is a thread on here about it however I haven't been able to find it.
I have a 2001 mrk 1 berlingo van and I've got no back lights on my dashboard and can't see anything when driving in the dark. All other warning lights work, I have taken the speedo cluster out but couldn't find any obvious of bulb.
Does any body know if I have missed something and there is a bulb or could it be a fuse?
Any help would be much appreciated.
Have you got to push stalks in your speedo cluster? The one on the right sets the mileage and the left hand one is a dash brightness adjuster. Just a thought.
Thanks for the reply, I was aware it does dim but it doesn't seem to work so that's what has lead me to believe that there is a possible bulb has gone.
On later models I think the fuse is F2 and 5 amps but mk1 it could be F30 10a but this powers indicators and interior lights to. I think it has been mentioned on the forum that they may be soldered in led`s but I could be wrong and barking up the wrong tree. Try a search on the forum.
Unless they've changed the design significantly between the 1999 and 2001 models, there's not one, but nearly half a dozen little 1.3W bulbs lighting up the dash. (I think it was 1.3W at least. Something in that area)
Multiple bulbs because it gives a more even illumination.
They're all held in with black 'twist off' holders that needs a quarter turn to lock/unlock. These holders can stick something fierce though, so pliers or other tool is a must. (Some may be under a piece that is held on with screws, too, if I remember correctly. )
But with no light at all, there's no chance that it's the bulbs. One or two gone, yes, but not all of them.
That leaves you with a fuse, broken cabling, faulty ground or an incompetent mechanic somewhere in the car's history.
Did it happen suddenly?
It did yeah, parts of the dash lights didn't fail before others they all went together. So that may lead to the later causes.
Ill check the fuses tomorrow when it's light and if I get chance take it apart again and have a poke around and see if I can find the bulbs.
If I'm right in saying I think it was built in the change over year to the mrk 2s so I don't know if it'll be different to half a dozen bulbs you suggested?
I know my hub assembly isn't the same as a mrk 1 as I had to get a replacement from the scrap yard and a one off a mrk 1 didn't fit properly.
Today 11:03 AM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
