  • 2 Vote(s) - 4 Average
eml light on
good morning
i have got a 05 berlingo multisapce 1.9d just had a full service and a cambelt and water pump change on it, it seem to now struggle to start but does, then while driving to work the eml comes on, any thoughts, its had a new alternator a few months ago which also brought the eml light on when it failed but when it was replaced it went out, would the battery also cause the light to come on.
thanks
Problems with the battery and alternator would normally light up the battery light. My faulty alternator didn't affect the EML.
The EML is usually faults with the ignition / emisions and the like.
You need to have the code(s) read to be any the wiser.
Did they disconnect the battery during the work and just reconnect it ? It could need a BSI reset have a read on BBA reman site or search the forum and you will find useful information.
(11-11-2013, 10:22 AM)ffrenchie Wrote:  Did they disconnect the battery during the work and just reconnect it ? It could need a BSI reset have a read on BBA reman site or search the forum and you will find useful information.
im not sure if they disconected the battery or not, they had put the belt on to tight but cam back on loosened it off, i took it on a road test all was ok till this morning on the way to work, i will try the reset thanks
I primed the fuel this morning before starting it and did the reset it started ok and light went out and hasnt come back on yet so fingers crossed its sorted now, thanks for your help
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
