  • 4 Vote(s) - 2.75 Average
[Brakes] vibration under braking
hi all my berlingo van is vibrating bad when Im braking any idear of problem its not ball joints suspention or brake discs renewed all .
Ah yes but are the surfaces of the disc and hub completely clean and free from rust so they sit flat and true. Sometimes if you give new discs a hard time from new they can warp.
  • ron
(13-11-2013, 08:24 PM)Tomcat3 Wrote:  Ah yes but are the surfaces of the disc and hub completely clean and free from rust so they sit flat and true. Sometimes if you give new discs a hard time from new they can warp.
hi bud yes cleaned both surfaces no contaminate as I could see really baffled.
I agree totally with Tomcat with the caveat that there are some crap cheap discs out there.Confusedalut:
Are you able to check the discs for runout? If you havent got a dial gauge, watch the disc where it spins through the pads. Measured mine with a feeler gauge.
HTH,
Griff
Landmark
Ex 1.4 Berlingo Multispace
(14-11-2013, 10:14 AM)Landmark Wrote:  Are you able to check the discs for runout? If you havent got a dial gauge, watch the disc where it spins through the pads. Measured mine with a feeler gauge.
HTH,
Griff
thankyou griff will check for runout:p
Today 10:00 AM
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
