  • 3 Vote(s) - 2 Average
Berlingo intermittent cutting out
Hi there , I'm new to this forum.
I have a 1.6hdi berlingo van , I have been having problems where the car looses power and cuts out during acceleration , this problem is very intermittent , I changed the fuel filter and it went away for a period of about a month, but it is back and happening again , it seems to be worse now , but I managed to drive to a citroen and Peugeot specialist without the problem occurring .
They have done a pressure / leak test on the injectors and all seems fine .
Any suggestions ?
Many thanks in advance
If it went away with a fuel filter change try it again. They're not expensive. If it goes away then you know which area to look in. It could be that a slight air leak has developed or you may have a load of crud in the tank that has blocked up the filter.
Malc
Stupid computer!
If its not your FF then check your Crankshaft sensor
Thanks guys , could it be a problem with the fuel pump also ?
It could be anything so just do one thing at a time ! Easy and cheap first !
Cheers guys , will change fuel filter again and see what happens
(15-11-2013, 11:20 AM)saffa365 Wrote:  Cheers guys , will change fuel filter again and see what happens
Any solution to your problem?
I had similar issues when i got mine first, would cut out when taking off or accelerating... found a joining connector on fuel line coming from tank where it takes a 90 degree bend on left hand side of engine..heading for filter housing
I dissconnected that joiner and blew back into tank with my mouth feeling alot of back pressure,, i knew the tank was in trouble so i dropped the diesel tank(actually very easy job) and took out gauge and found the screen in the tank totally gunked up with grime and grit..cleaned it all out and never had a fuel problem since..
My Vehicles: 2015 Berlingo Enterprise Van 75 1.6Hdi
                   2021 Nissan Qashqui 1.5DCi
Today 11:03 AM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
