  • 5 Vote(s) - 2.8 Average
2.0hdi glow plug location
Hi my 2006 2.0hdi partner is getting harder to start and is chugging in 4th and 5th gears. Does anyone know why this is if it's the glow plugs etc? If so where are they located as I can't find them.
Any error codes listed on a reader??
Chugging in higher gears is not related to glowplugs on the 2.0 hdi.
(16-11-2013, 02:59 PM)steve valentine Wrote:  Chugging in higher gears is not related to glowplugs on the 2.0 hdi.
any idea what it could possibly be? No error displaying
The HDi engines hardly use the glowplugs. They are on the front of the head, joined together by the thick wire. But don't suspect them at this time. Suggest you may have air in the fuel system. Had this before with a non turbo diesel. B*gger to start, but when running was OK. Was pulling in air before fuel filter. When left overnight, fuel would drop back to tank.
(16-11-2013, 10:28 PM)Modmytop Wrote:  The HDi engines hardly use the glowplugs. They are on the front of the head, joined together by the thick wire. But don't suspect them at this time. Suggest you may have air in the fuel system. Had this before with a non turbo diesel. B*gger to start, but when running was OK. Was pulling in air before fuel filter. When left overnight, fuel would drop back to tank.
Yea it's normally when left overnight it's hard to start in morning. Think this explains chugging in higher gears?
My Berlingo Multispaces
Yesterday 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
