  • 3 Vote(s) - 3.67 Average
Ignition barrell changed
Can someone let me know if it is ok to put an ignition barrel from a scrapped van into my 05 berlingo van ,my key is very hard to turn and sometimes it can take a lot of attempts to get it to work ,also is it something I can do myself or is it a job for a garage ,,,,cheers
The barrel can be swapped, trouble is that you current key has a chip in it to match your cars immobiliser system, and the new key will not match. If your key is a push button plip key, then you can change the chip from one key to another. If you have the basic key, the hip cannot be removed, so the whole job becomes much harder, and you will need the help of someone who can supply you wit,hm a programmed key or chip.[/i]
Thanks for that info ,il be getting the new barrel tomorrow in the post ,
The key I've got is a push button type so I should be able to put the chip in the new key,will I need to put my imobalizer in the new barrel forbid to work ?
I'm having a new ignition barrel fitted and im changing the chip in the key so I can start the van my question is how do I get a spare key made to fit the new barrel,I don't have a key code card for the van . I do have a key with remote and a spare chip inside also a blank key .how do I get it cut the same as the new key that will then start my van if ever needed .
The new barrel is or a scrap van .
You can get the key code from the citroen dealer for around £15 some key cutting shop's will do key for you i think you have to put the key on the dash and turn ing'n on off ten time's to set the code.
Is the code what's needed to cut the keys shape or tp programme the chip as I cam only give citreon my van reg and chassis number but the new barrel is from an unknown scrap van?
Your best bet would be find an auto locksmith in your area and they will be able to cut you a key and program it for you. As you can drive the van take it to them and you dont get a call out fee.
  • cstopforth
(19-11-2013, 09:47 PM)cstopforth Wrote:  Is the code what's needed to cut the keys shape or tp programme the chip as I cam only give citreon my van reg and chassis number but the new barrel is from an unknown scrap van?
Take your old key to be cut then the new key will have a new chip inside you put the new key on the dash put the old key in the ignition turn on /off ten time's with out starting engine this should code the new key there may be a time limit of about 10 sec i will find out the new key will cost around £50
Thanks that great
16-08-2026 08:18 AM
16-08-2026 07:56 AM
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
Strange whining noise
05-08-2026 04:28 PM
