Threads: 52
Thanks Given: 87
5
Came across
this excellent pictorial documentation replacing a turbo and air cooler. Thought it was worth posting.
Threads: 16
Thanks Given: 46
5
Interesting, but depressing at the same time, don't you just hate the complexity of modern engines & just to save a bit of fuel & emissions? The engine does seem rather corroded & rusty though, mine is same age & mileage & quite clean & I've never cleaned it apart from the odd wipe & it lives outside.
Threads: 52
Thanks Given: 87
5
LOL I long for the days when you could pop the bonnet and see every part of the motor. Adjust the points and timing, gap the plugs, maybe rebuild the carb if necessary and you were good to go. And petrol, at least in the US, was $0.25 a gallon. Ahhhhh them simple times.
Threads: 52
Thanks Given: 87
5
Quote:Room under the bonnet don't remind me in the good old days you could sit in the engine bay quite easily.... Time to take the rose tints off I think
Sadly, yes. Just turned 68 a couple of weeks ago. So both feet firmly entrenched in geezerland.
Threads: 51
Thanks Given: 23
That almost looks do-able even for me. The blades on that turbo look well manky.
Malc
Stupid computer!
