  • 8 Vote(s) - 2.5 Average
dreaded "airbag light"
Hi all,
I am currently having issues with a 2006 1.9d berlingo with the airbag light on.:brickwall:
these are the codes it has come with using main dealer software:-
1) permanent fault: ECU internal (van interface) Not defined
2) permanent fault: Passenger's airbag deactivation Not defined
The van doesnt have a passenger airbag installed! we have tried to reconfigure the settings but the faults still remain.
Have done a continuity check from BSF to BSI found that one red wire (IA6) with no signal!
can anyone else shed any light on this or i am missing something.
cheers shane
Take a look at this post Shane, it may help!
http://www.berlingoforum.co.uk/showthread.php?tid=8119
Have you tried something simple like the connectors under the seats, they used to cause the air bag light to come on on my MK2
Things get pushed under the seats and when the seats move it disturbs the connectors. ( they don't have to be disconnected to be a problem )
Simply turn the car off, reseat all the connectors under each seat and try again.
T1ny
[-] The following 1 user says Thank You to T1NY for this post:
  • shane_evans
(22-11-2013, 12:28 PM)shane_evans Wrote:  Hi all,
cheers shane
I would first do what Tiny said, if no joy physically chase the twisted wire pair back from the engine fuse box for signs of damage, it runs down from engine fuse box into side panel, up and across under windscreen wipers(remove grill) and down through bulkhead. I was lucky the white wire of the twisted pair was burnt out just a few inches out from the engine fuse box.
[Image: 2ey7szc.jpg]
[Image: 3010yrt.jpg]
[Image: 2moz57n.jpg]
[Image: 23tgnyo.jpg]
If wires are good I think Rustscrats can guide you further :thumbsup:
[-] The following 1 user says Thank You to mitumatu for this post:
  • shane_evans
Hi thanks for the replies. :-)
I tried cleaning the connectors which didnt work unfortunately.
I will check the twisted wires :-)
I had one last week where there was a whole raft of faults. It wasn't until I'd pulled out the BSI and checked every wire for continuity, I realised there was a fuse missing! The owner confessed to tinkering a little before he'd called me in...
[-] The following 2 users say Thank You to addo for this post:
  • Ol'Jeffers, shane_evans
Sorted cheers for that. Was broken wire on the twisted wires!!
Cheers for the help :-)
[-] The following 1 user says Thank You to shane_evans for this post:
  • addo
Addo,I'm surprised at a man of your calibre not checking the basics first. I've NEVER been caught out like that.:whistle::whistle:
  • addo
I'm afflicted with near terminal honesty.
I suppose the fuse was near a terminal
Malc
Stupid computer!
[-] The following 1 user says Thank You to crickleymal for this post:
  • addo
Yesterday 10:15 PM
» Replies: 41
What is this?
Yesterday 07:23 PM
Iceland Trip and modifications
Last Post: Vantour Berlingo
Yesterday 06:05 PM
Engine judder at 1800 rpm
Last Post: rodthemod
Yesterday 04:58 PM
Heater blower not working
12-09-2024 12:22 PM
Key.... repaired... but how much for a New fob
Last Post: Gadgetman
12-09-2024 08:19 AM
Correct FAP Tank? 2012 plate L2 van
11-09-2024 11:34 AM
High Beam LED upgrade possible? YES
10-09-2024 10:31 PM
ABS Sensor Fault M59 1.6HDI
Last Post: BaysideM59
10-09-2024 08:42 PM
Knocking sound from front end when going over ro...
Last Post: markscotford
10-09-2024 08:04 PM
