Threads: 44
Thanks Received: 67 in 56 posts
Thanks Given: 9
10
It's getting worst and worst to the point that sometimes it takes 10 slams of the door in order for the message to disappear, once it's gone, then the central locking works. I thought it will be easy fix but I did not see where the sensor on the front door might be so I was hoping somebody will save my time investigating. Nothing is mentioned inside the Haynes manual.
Threads: 51
Thanks Given: 23
That's a good question, I don't know either and I can see it would be handy to know.
Malc
Stupid computer!
Threads: 29
Thanks Given: 67
20
My missus has a panic when she sees the "left front door open" message and she has to get out and go back to check the house is locked
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post
• RolyG
Threads: 2
What happens when you physically push the interior light switch close..try when both door are open that will show if it is that which controls the message...can do the same with door locks using a screwdriver..just use it the same way as the striker bar on the doorpost strikes the lock just make sure you open again with the handle before slamming the door shut again as the locking mechanism is in the closed position and your door will just bounce open again..
Threads: 13
Thanks Received: 91 in 80 posts
Thanks Given: 11
My front and rear interior lights are permanently off , incase "right door open" flashes whilst driving as this causes both interior lights to flash constantly (which does ones head in :brickwall: )
I can go days without this malfunction or it happens for a dozen attempts and van is left unlocked over night or worse .... in birmingham :eek:
Threads: 50
Thanks Given: 743
It's likely to be a worn out or faulty switch or activation mechanism in that door's latch assembly.
First I'd check the wiring with a meter as a broken wire will give the same symptoms.
Then I'd strip out the door and check that the switch is being activated.
If you strip the door out you can (probably) operate the swich manually to check if the light goes out.
Threads: 67
Thanks Given: 1,045
The switch is inside the latch assembly. I think his will be the same as a Xantia, P406 etc - so long as it is/isn't a deadlocking one (donor must match type). Buy from French breaker if possible, as driver's door is the (less used) passenger side!
Threads: 51
Thanks Given: 23
(27-11-2013, 08:15 AM)addo Wrote: Buy from French breaker if possible, as driver's door is the (less used) passenger side!
Aargh, it's obviously too early in the morning for me! :whistle: I had to really think about that for a while. It makes perfect sense now I think about it.
unny:
Malc
Stupid computer!
