  • 2 Vote(s) - 2 Average
smoke leaking into airvents??
there is smoke or steam leaking into my air con does anyone have anyideas what it could be?? it started about 2days ago and is causing the window to fog up aswell as poisioning me!anyone have any ideas what it could be???
i opend the bonet and couldnt see any leeks from the exaust of any pipes?? :brickwall:
What does it smell like? Does it smell like exhaust fumes?
its smells abit like coolant but its very thick to be steam thats why i think its excaust fumes..
Heater matrix leaking.
Check your coolant level, if heater matrix is leaking then your coolant level will gradually drop.
Otherwise it could be fumes from a leak somewhere in the exhaust system or possibly fumes leaking from a leaky injector seal (assuming you have a diesel model). I would have thought you'd be able to smell if it was exhaust fumes though.
found out it was the internal radiator lads. 8 and a halfhour job but got it fixed anyway Smile_
[-] The following 2 users say Thank You to mackinsberlingo for this post:
  • addo, Ol'Jeffers
Glad it's done. I often see ones where just the O-rings between the plastic parts have turned brittle and cracked with age and heat. Means they steam for a long time before they start dribbling visibly. If you were tight you could probably replace them and add a smear of Silastic.
Yesterday 04:12 PM
Yesterday 12:46 PM
Yesterday 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
