  • 5 Vote(s) - 2.4 Average
Won't Lock
So I just bought a berlingo yesterday (2001 I think) and for some reason the car wont lock. The central locking works fine, it's just as soon as the car locks it unlocks immediately after. I think I've narrowed it down to two possible cause (but I could be completely wrong).
1. The light on the dash that indicates that a door is open is also on. I've tried closing all the doors on the car again and again but there's no change. I think the car won't lock if it thinks one of the doors are open.
2. The lock on the boot door is broken I think. The handle works fine I can close and open it fine, the problem is the key wont turn in it and I really don't want to force it in case I break the key.
Just thought I'd try here first before I have to take it to someone to have a look at because at this stage I'm completely stomped.
Thanks!
Yes, it's unlocking because one of the doors is registering as open. You could try isolating by in turn disconnecting the door harness connectors at one and then the other front doors (don't try to shut the door with the connector unscrewed!) - the back door is harder because you'll have to remove the inner trim and liner panels to unplug the lock connector.
Just disconnected each door and it turns out its the front driver's side door that's causing the problem. Thanks for the information. My problem now is fixing it. Is it an easy fix?
It's probably worn contacts of the switch inside the door lock itself. A Xantia or P406 one will fit if the plug looks the same. If you can borrow a "known good" latch, unplug the harness from the actual one after removing the door card and carefully peeling back the foam shielding, and connect up the trial unit to the plug.
Trick it by flipping the cogs to closed with a screwdriver tip and see if the car now thinks all doors are shut. If so, replace the latch. If not, suspect broken wires in the flexible conduit between door and jamb.
Thanks a lot! I'll definitely give it a try.
Should I buy this van?
Last Post: Duggie12
Today 09:27 PM
sliding door panel removal
Last Post: mojito
Today 07:13 PM
Twin Cam Chain Snapped need some Parts Advice
Last Post: kingy1912
Today 01:10 PM
Rumbling Noise 55-65mph
Today 01:06 PM
XL tyres
Today 01:03 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
Outer cv boot replacement
22-03-2025 10:13 PM
22-03-2025 10:02 PM
Diagnostic Plug
22-03-2025 09:55 PM
