  • 6 Vote(s) - 3 Average
Berlingo 1.6hdi non start eco mode
Afternoon all,
Having had the Berlingo a few weeks I have ran into a few problems! Firstly the car needed a new EGR valve, luckily that was fix at the dealers expense given the cost of the Citroen part!
This afternoon I was fitting a new cd player and autoleads kit and the car has gone into eco mode on the dashboard display. Neither my normal key or spare key will start the car. I have tried charging the battery to no avail, the engine turns over fine so I'm pretty sure that the battery isn't the case (although its not fully charged). I follow the procedure for the BSI shutdown but got a little confused at points:
1) when it talks of turning the side lights on should these illuminate? Mine dont.
2) when you try and start the engine at the end do you start it from outside the car I presume.
This didn't seem to work but I may need to run through it again to ensure I followed the procedure correctly.
Any other ideas on how I can fix this incredibly annoying problem? Any help would be greatly appreciated!
Cheers
Greg
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
