01-12-2013, 09:03 PM
I have an ultra reliable 1.9d Berlingo 1, my dad is so impressed he went and bought himself a 1.9d Berlingo II 2003 model. Unfortunately he swallowed the 'I've got a new fuel sender unit it just needs fitting' line and parted with his cash - leaving me to sort it out as I'm fed up with recovering him when he runs out of fuel. Whilst removing the tank I found that it had recently been in and out ( nice big retaining washers leaving a distinct mark when refitted) and the new sender in the nice Genuine part box was indeed the old unit. This prompted me to check the resistances on both units - almost identical on max / min. I refitted the newer one to the tank. Before bolting the tank up I checked the reading at the end of the short wire from sender - no readings. Whoever fitted the unit had poked the multiplug with a rather fat test probe and enlarged the terminals in the plug - careful fixing and I now have readings on end of lead where it joins loom on vehicle. Tank on jack put approx 5 gallons in no gauge movement. Pins in multiplug on wiring loom also stretched by the affore mentioned probe - more careful fixing and I have a reading on gauge (1/2 tank) hooray! Added another 4 gallons of juice - still half a tank
Refitted tank pipes etc. and tested with diagnostic tool. (Autel DS708) When fuel gauge activated it goes 1/4 wait 1/2 wait wait wait wait wait and down again (when temp gauge activated it goes 1/4 wait 1/2 wait 3/4 wait full wait down again)
By the way fuel gauge started dropping immediately fuel is used and ran out at 1/4 tank without fuel light coming on. With sender disconnect gauge sits at bottom with light on.
Does this sound like a BSI or an in dash failure?
I don't have Lexia to test BSi at present but may order it as most of the problems I see relating to CAN, VAN or BSI issues tend to be on Citroens and Peugeots.
Refitted tank pipes etc. and tested with diagnostic tool. (Autel DS708) When fuel gauge activated it goes 1/4 wait 1/2 wait wait wait wait wait and down again (when temp gauge activated it goes 1/4 wait 1/2 wait 3/4 wait full wait down again)By the way fuel gauge started dropping immediately fuel is used and ran out at 1/4 tank without fuel light coming on. With sender disconnect gauge sits at bottom with light on.
