Threads: 13
Thanks Received: 13 in 3 posts
Thanks Given: 9
02-12-2013, 10:40 AM
(This post was last modified: 02-12-2013, 10:43 AM by wertyu2007.)
if i go up hill a 4th gear stick vibration is quite bad
on the level , vibration still there but not quite so bad .
you can see the gear stick moving about 3cm either way fast .
any ideas to check , im in portugal drove it here from coventry so dont have all my tools etc , o be great to have an idea before starting .
thanks
Threads: 17
Thanks Received: 40 in 32 posts
Thanks Given: 6
Hi,
You don't say what motor it is - if petrol is it missfiring?
Griff
Landmark
Ex 1.4 Berlingo Multispace
Threads: 32
Thanks Given: 13
Are you sure the tracking / wheel balancing is all good??
Threads: 50
Thanks Given: 743
If it's just the gearstick vibrating I would be checking the engine mountings
as they do become loose.
Thanks Given: 188
23
What motor have you got and how many miles on the clock, has the van had a hard heavy load life. Could be engine mounts are you making the engine labour going up hill when it would be better to change down. Have a look at the gearchange linkage while you are under there and check the play in that to.
Are we there yet?????
Threads: 13
Thanks Given: 9
21-02-2014, 02:44 PM
(This post was last modified: 21-02-2014, 02:55 PM by wertyu2007.)
sorry about that , ask a question and then scarper , anyway the berlingo got me all the way to portugal and back , might go back its that cold , im virtually a mediterranean now after 3 months lol .
it vibrated all the way there and all the ways back even though the engine and the rest did not miss a beat .
im going to start work on it monday i pulled my leg out on the beach just before i set off so recovering off that but hopefully get looking into all you advice monday .
1.9d 2001 berlingo van
81000 treated like a princess since 60000 lol
engine mounts solid no visible play
not an engine problem i dont think (ie runs great but i look into this further )
fully serviced every few thou and recently done prior to trip
im leaning toward , bearing 4th gear or drive shaft alignment ? but i always think the worse first .
thanks all
