  • 3 Vote(s) - 4.33 Average
[Steering & Suspension] Sticking Steering?
As I went to reverse out of the drive this morning I turned the steering wheel and just for a brief moment it felt like the tyres were stuck to the ground. After that it was ok and turned normally. Any ideas?
I have to confess the car has felt less stable than normal recently. I can't see anything wrong with the wheels and tyres. When the new tyres arrive next week I'm going to get the tracking checked as I've hit some big bumps recently.
Malc
Stupid computer!
First I'd check the PAS fluid level, then the aux belt, then look at the belt as the engine idled and I turned the wheel about 180 back and forth a few times, looking for erratic belt motion. You can load up the pump even more to listen for pump problems vs belt drive by pushing the footbrake hard as you test steer like the above.
  • crickleymal
Have a look at the u/j at the bottom of the rack it may have dried out and they get harder to turn. Get some lube on it and see if it gets any easier.
  • crickleymal
Last Post: Cumbrian
Today 09:02 PM
Does My Van Have A Tracker ?
Today 09:25 AM
Yesterday 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
Barn Doors - Lockign Mechanism HELP?
10-06-2025 07:13 AM
09-06-2025 06:25 AM
» Replies: 34
Sump, Any good swear words?
04-06-2025 12:34 PM
