Threads: 3
Hi all
Is it possible to swap the passenger seat base for the drivers one as all the support in mine has now gone
Threads: 11
Thanks Received: 19 in 14 posts
Thanks Given: 3
yes, exactly the same. I retrimmed my seats in leather so I know for sure. not as simple as you may think though. if you need any help or advice let me know
Threads: 43
Thanks Received: 42 in 37 posts
Thanks Given: 3
i had the same problem with my drivers seat i think lots of people do. i took the seat out and removed the base fabric and covered all the foam with a new layer of 11/2 in foam which i used carpet spray glue to hold it in place. then replaced the fabric and replaced the seat. it took a bit of time but was worth it.
The following 1 user says Thank You to landcrab for this post:1 user says Thank You to landcrab for this post
• ron
Threads: 67
Thanks Given: 237
50
A tried and tested repair ^^^^ a bit like using new webbing to repair an old sofa that has a sagging seat cushion - oh for the days of being skint with rose tinted glasses.
I'm waiting for a dry day and time off work to look at my drivers seat as when pushing the clutch pedal down the underneath of my my thigh is bottoming out on the front edge of the seat before the clutch is fully home, I don't like toe flexure ! My Berlingo is a van with drivers and passenger seats different, passenger one is the fold down type.
Will update when I get it done.
Serieal Berlingo owner
Threads: 3
Took both seats out this afternoon swapped over seat bases and spring supports and my drivers seat is now like brand new:lol::lol: really easy job
Threads: 11
Thanks Given: 3
great job, hope my email helped lol
