  • 4 Vote(s) - 3 Average
Front windscreen washer
Hi Folks
I've got a problem with the front windscreen washer, I now only get a little bit of water coming through, I've checked inside the engine bay and there is washer fluid coming through into the engine bay, so I'm assuming that the pipe has become damaged.
Q how easy is it to access the pipework and replace it?
Thanks in advance.
I would check;1) the jets are clear,2) the pipes are clear(can fill with gunge).3) flush out the bottle (stick hose in to bottom & turn full on) 4)make sure the pump is running & working.Good luck.:thumbsup:
Right folks, its definately the pipe work from the pump, how easy is it to get in from the wheel arch to repair the problem?
Thanks in advance
Remove inner wing and you can get to it.
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
