  • 26 Vote(s) - 3.15 Average
Leaking windscreen or aerial mount????
Hi all, had a bit of heavy rain yesterday and today and have got some water ingress into the vehicle via the top windscreen rubber, or maybe the base of the aerial mount???
Has anyone had this problem before...... seems to be dripping in and pooling above the courtesy light fascia!!! Then dripping on my head when going around roundabouts etc Sad
Is this another lovely berlingo fault..... thought I had cured them all!!!
Yours hopefullyIdea
Have you tried a hat, Adam?:thumbsup:
Can't find one big enough to fit the Berlingo's roof......???
would this affect the mpg do you think......Smile
The leak?
Depends how much water gets in.
Anyway, it's not raining.:thumbsup:
On mine it was the aerial base leaking. Picked up a new one and replaced it. Before seating it onto the roof i used a small amunt of clear silicon and has been fine ever since
[-] The following 1 user says Thank You to 800HDI for this post:
  • adam3rdcanvey
cheers,
have siliconed the outside of the mount where it joins the roof for the mo....
will do for a couple of months!!! Smile
"Is this another lovely berlingo fault..... thought I had cured them all!!!"
and you haven't even started on the electrics yet !
(06-06-2011, 07:39 PM)Coco Wrote:  "Is this another lovely berlingo fault..... thought I had cured them all!!!"
hmmmmmmmmmmmmmm.... lets not tempt fateSmile Smile
This has been mentioned before so I don't think that you're the first with this problem unfortunately
I had the same problem and traced it to the aerial. When I took the aerial off there was two holes where the aerila fitted into the roof, rather than get the silicone gun out I fitted two different sized O-rings onto the aerial, nice tidy job and has not leaked since.
Roly
2004 Berlingo 600 Enterprise
Confusedafesex: If in doubt flat out!!Confusedafesex:
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
