  • 2 Vote(s) - 4 Average
hello
hi just bought 2004 1.9d berlingo van ....
I had a kangoo 1.5dci for 12months before that
I must say the 1.9 does seem underpowered compared to the kangoo
I wanting a spare key cut/ programmed if anyone can help
[-] The following 1 user says Thank You to agh321 for this post:
  • Ol'Jeffers
Welcome.You have bought a N/A slug that is bombproof & economical.
At least you won't have turbo problems.Confusedalut:
when I bought my 1.9 berlingo it had a high reving tickover ie 1200
any way when my mechanic fitted a new cam belt he adjusted the tickover to 1000 but when starting from cold it would judder and smoke for 30 seconds until I pumped the throttle pedal
so I thought s**t I've bought a bad n
any way today I've put a new set of glow plugs in and cleaned the egr valve and the improvement is night and day
now revs to 4500revs starts on second turn of starter motor and purs on tickover
I don't know if ime more pleased or relived at the results
took it up a hill today and thrashed it for 2 miles 4000 revs + no smoke pulled all the way and no issues what's so ever didn't even get hot
so I recomend a set of glow plugs £33 Ngk ones and a quick clean of the egr valve , it's still black inside but it scraped 3mm of soot off and wiped it with a cloth soaked in petrol
  • addo
Thanks for posting a follow up, to show what's worked. Key sorted yet?
(22-12-2013, 08:41 PM)agh321 Wrote:  when I bought my 1.9 berlingo it had a high reving tickover ie 1200
Cellulose thinners works a lot better.:thumbsup:
Hello agh welcome to the forum glad you got it sorted
Hi again
1.9d poor economy 35.5mpg 87,000 miles
new cam belt new discs new brake pads new tyres new heater plugs oil filters ect
before I did all that mpg was 38mpg
now it's 35mpg could it be the cold weather cos I was expecting 40+ with all the service parts
Yesterday 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
