10-12-2013, 01:02 PM
Yeah, it's me and my 1.4i again...
After the oil-change and sump cleanout, I've only driven Shorter trips to the store and such(Don't like unnecessary driving. It's expensive... )
Anyway, on friday I had to drive to work instead of taking the bus, and this time it heated up to the '3/4' mark and hovered there, With an occasional Climb a mm or so higher. Of course, the heater was running at full blast because of yeah, Winter...
It was also feeling 'not right' With regards to Power in 5th gir, so when I got back home I pulled the plugs and ran a compression test.
This time I used a 'quality' gauge I borrowed from a friend(mine is 'buried' somewhere in my garage.) and instead of hitting around 10Bar, it showed 12Bar compression. 20% higher than it's supposed to be.
So, my 'el cheapo' gauge may be slightly off...
And high compression may explain the 'not right' feeling, I expect With hesitation and lack of grunt.
But can it also explain it running hot?
Today I'll go over the cams and check the clearances.
(I thought I did a decent job of that earlier. There wasn't that much carbon buildup, either, and cleaned it up pretty well when I did the headgasket)
