  • 2 Vote(s) - 1.5 Average
Temperature problem
Hi I have BERLINGO (M59) ESTATE VAN 1.4i 75 (TU3JP), I have changed thermostat fitting, and the water temperature sensor, but I still have problem with engine temperature. I need to drive at list 30 min to reach the temp of 85 C. Before that, engine temp is 60C but that is not accure. Water pump is ok, and everything else look good. Where can be the problem? Thanks!
maybe a faulty guage? although the weather has been very cold so may just take a while to warm up?
Yes, when the weather is too cold I have this problem. When the weather temp. is bellow the 0. What do you think, where it can be the problem?
Thanks!
What temperature is it in Macedonia ??
Edit ..... I've just looked at a map to see where you are and it should be about 3 Centigrade.
If the gauge will read 85 when fully warmed up then it cannot be reading incorrectly as this will be the correct temperature, try placing something over the grill / radiator to stop cold air entering and see if it warms up any quicker, plastic sheet or cardboard will do the trick.
Watch out for overheating of course.
My 1.9D takes about 5Km to reach 85*C when 3*C
Yesterday 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
