  • 3 Vote(s) - 1.67 Average
wing mirror plastic cover lh
hi
my passenger wing mirror cover LH needs replacing-
would anyone like to suggest the best method?
there is a slot at the base of the cover as if to enter (a screwdriver?) to prise the cover off-
but I am a bit hesitant as I am not sure if this is the correct method-
all help appreciated.
pop the glass bit out, you will see some tabs that need prising a bit to release the rest, you will also need to fold the mirror in to get the bottom bit out, have a couple of flat blade screw drivers to help it off
(15-12-2013, 03:32 PM)finny Wrote:  pop the glass bit out, you will see some tabs that need prising a bit to release the rest, you will also need to fold the mirror in to get the bottom bit out, have a couple of flat blade screw drivers to help it off
cheers for that-just got back from a walk and a bit dark to try tonight but will let you know how I go
thanks
mike
how did you get on?
63 plate Berlingo working hard.....
i'm trying to do the same but would appreciate advice on how to pop the mirror out so I can get the plastic housing off - thanks in advance
(10-11-2015, 08:54 AM)muftib Wrote:  i'm trying to do the same but would appreciate advice on how to pop the mirror out so I can get the plastic housing off - thanks in advance
Hi muftib
A while ago I needed to have my mirror cover resprayed and posted a photo of the mirror with the cover removed.  I shows where the slots are that the cover clips into.  The bloke at the spray shop used some plastic tools to release the cover.  Hope this helps.
Mark
http://www.berlingoforum.co.uk/thread-10035.html
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
the glass just pops out, pull it firmly from a corner with your fingers
Last Post: magoo1
Yesterday 06:31 PM
» Replies: 74
Last Post: Dyane6
Yesterday 05:19 PM
1.6hdi starting problem
14-10-2026 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
