  • 4 Vote(s) - 2.25 Average
How to disable the safety belt warning ?
I live on a farm, and we use the Bingo on the farm tracks a lot, and across the fields. At such slow speeds, and getting out for opening gates etc every minute or so, that the belts are not used.
How can I stop the warning beep please ? It gets very loud after a minute, and the dogs don't like that. (I know it stops after 2 mins or so)
I'd rather not delve into the instrument panel, but can one cut a wire near the floor seat belt clip, please ?
T I A
Not sure but probably more like put a shorting link in the plug under the seat.
Malc
Stupid computer!
(17-12-2013, 01:19 PM)crickleymal Wrote:  Not sure but probably more like put a shorting link in the plug under the seat.
What he says ^^ link out the switch at the seatbelt itself.
Plug the seatbelt in and then sit down.
[-] The following 1 user says Thank You to steve valentine for this post:
  • Evolve
Have two seat belt receivers and a dummy end left plugged in and use the second for everyday use :whistle::whistle:
Confusedillyme:
Fleabay has them all over. Cheap as chips, shipped ex-HK or China.
thanks - a couple of good solutions for me to chase up.
TA!
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
