My berlingo 1.9 steering went stiff and pulsed when turning. I replaced the pump and fluid and also checked the bottom connection on the steering column that stiffens ups, I am at wits end as the next stage is to replace the rack or have I over looked something. Hope your able to help...thanks
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
What about the bearings at the top of the suspension struts, ? are they OK. The ball joints at the bottom can seize as can the track rod end ball joints, (though not very common )
Disconnect the t/rod ends and then try the steering. If still stiff you've narrowed down the problem area.
Threads: 50
Thanks Given: 743
Try lubing the steering column UJs.....been done many times.
