  • 3 Vote(s) - 3.33 Average
Colour coding MK1
Hey guys, a few questions
I have an X reg Berlingo, I want to colour code the bumpers so it's all matching white. Has this been done before? Not sure if it will look good.
Also, will I need a special flexible-plastic paint?
Now I know my van is single stage paint (no lacquer) will the bumper look a lot different if I finish it with a lacquer over the base?
It will look a lot shinier.Solid white doesn't usually polish up to a good shine.Confusedalut:
  • BLINGONOOB
Often the plain bumpers are a wholly different plastic. You'll need an adhesion promoting primer and a super thorough pre-clean as most bumpers will have been treated with silicone type dressings at some stage -these must be removed 110%.
Solid white 2K will give a respectable gloss off the gun.
  • BLINGONOOB
I did think about full white not as it is now but I reckon it'd be too much, back bumper is black for the same reason.
I treated the old girl to new bumpers as the old ones were a bit shabby (from previous owner)
[Image: i214w7.jpg]
Quote:Solid white 2K will give a respectable gloss off the gun.
I've never worked with 2k paint.. will normal spray paint and lacquer be flexible enough for a bumper?
(18-12-2013, 09:18 PM)steve valentine Wrote:  I did think about full white not as it is now but I reckon it'd be too much, back bumper is black for the same reason.
That's a fine example :thumbsup: Can I ask what wheels they are?
Citroen steel rims.
Eurolee had a super modded mk1 , his avatar is a side view of it fully coded ! There are better pics through his posts , looks mint , if you like that sort of thing :thumbsup: Confusedanta:
Users browsing this thread: 2 Guest(s)
Today 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
