Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
Hey guys, after 8 months of having my berlingo ive finally got round to blanking off the EGR Valve on my 1.6hdi it hasn't put a light on the dash either so that's another thing ticked off the list.
Threads: 67
Thanks Given: 237
50
Well done.
Did your EGR and inlet piping / manifold need cleaning and also have you noticed any difference in the running of the vehicle yet ?
Serieal Berlingo owner
Threads: 37
Thanks Given: 11
To be honest I didn't even look at the inlet or piping, I just blanked it off to prevent any more gunk in the engine. Ive only taken it round the block will keep you posted on how she drives.
Threads: 37
Thanks Given: 11
Yes that's right spot on lossened two bolt and fitted the blanking plate,took her for a good drive today and runs the very same. It's a 2007 mk2 1.6hdi which is the same engine in the mk3.
Threads: 11
Thanks Received: 22 in 18 posts
Thanks Given: 50
I blanked my egr valve off , 2005 2.0 hdi , it ran ok for @15 miles then ran like the exhaust was blocked and wouldnt rev over 2000 rpm ! It was showing a air flow fault (cannot remember what code ) I took the plate out and it went fine after resetting the codes !
Threads: 37
Thanks Given: 11
Blimey that's got me worried now touch wood it will be ok.
Threads: 16
Thanks Given: 46
5
Can the ecu not be reset by a garage, if the blanking plates are available one assumes they can be made to work?
Threads: 11
Thanks Given: 50
Thats what i thought ! After reading up about it it should only make your engine run better ! But my car wouldnt have it !
Threads: 23
Thanks Given: 50
29
You can get the EGR deleted with a map saves trying to fit a blanking plate
