  • 1 Vote(s) - 3 Average
Sliding doors adjustment
Do the side doors on the 'lingo need periodic adjustment?
I ask as:
- The driver's side sliding door does not easily come off the open 'latch', there is a bit of a knack to it, while the passenger side is fine.
- The drivers side sliding door also impacts the driver's door slightly, paint has come away from the very top edge of the door.
Thanks for any help!
2004 1.9D Multispace/Budget crew cab work van!
[-] The following 1 user says Thank You to chronyx for this post:
  • CandR
(23-12-2013, 04:50 PM)chronyx Wrote:  Do the side doors on the 'lingo need periodic adjustment?
Ah! Me too... noticed similar last week (thought: Well, she's more than ten years old....)
Looking forward to answers! Smile
Hi there
I just adjusted my doors slightly Today, work on both sides took about 30 minutes,
I followed this link: http://www.squidoo.com/slidingdoor
Tho there is no need to remove the whole handle cover as described, just bend it carefully away (inwards), and use fitting tools to loosen and tighten.
it got better, and remote key works again (it locks and open).
BUT i am not satisfied get, still the sliding door on one side are not so tight as the other one, the door is about 2 millimeter further "out" then the passenger front door, and it needs to be more tight/closer. When i push the door, it is some wiggle..
I tighten screws all the way on the door.. is it more i should look for?.. Must i change rails on the top? Is it possible to adjust the rails on the top?
My Car INFO:
CITROËN BERLINGO (MF) 1.4 i (MFKFX, MFKFW)
2005 Mod
Volum: 1360 KW: 55 HK: 75 Fuel: Gasoline
[-] The following 1 user says Thank You to Varg for this post:
  • chronyx
(24-02-2014, 11:43 AM)Varg Wrote:  Hi there
Many thanks for the link. Let us know how the next stage goes!
Richard.
I had the same problem with mine, a quick squirt with GT85 and it's been smooth for six months now. Releases easily and slides so much better.
Grease or gt85 does not make the door more tight does it?
I would love good manual for doing a sliding door service Wink
My Car INFO:
2005 Mod
Berlingo undertray
Today 04:46 PM
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
