  • 1 Vote(s) - 2 Average
Fascia panels
Is it an easy procedure to pull off the matt silver facia panel in front of the passenger seat, (airbag cover), without activating the airbag and the small panel directly above the gear lever?
Airbags can be naughty , my advice would be speak to dealer (:twistedSmile or air bag specialist.
There are procedures for different makes and models , for example de energise the circuit and leave for a set time to discharge capacitors etc , unless your sure, not worth the risk at home.
Jonb
[-] The following 1 user says Thank You to jonb for this post:
  • Tonyash
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
