  • 4 Vote(s) - 3.75 Average
REAR SLIDING DOOR RUBBER SEAL
Hi, does anyone know the best adhesive etc to repair torn bottom rubber seal at rear sliding door opening ?
If not, any info about part number / cost ? Thanks.
Glued the seal adjacent to door handle with this as split http://www.toolstation.com/shop/Adhesive...340/p86374
Don't know about other superglues or cyno type adhesive but this seems to stick lick the proverbial to a blanket
  • taxi
Tiger seal.
[-] The following 1 user says Thank You to steve valentine for this post:
  • taxi
I think washing machine sealant would work well, I've used it for many similar tasks.
You can get it from any domestic appliance parts wholesaler.
Glasgow Appliances will stock it!
  • taxi
Hi
De grease the seal fully , I use to repair them with super glue then silicone spray the seal to aid fitting and prevent binding.
Although a new seal might be required if the damage is extensive.
Regards
Jon
[-] The following 1 user says Thank You to jonb for this post:
  • taxi
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
