  • 4 Vote(s) - 2 Average
Indicators... probably com2000
Ok, I have a problem with my stalks:
1) If i leave my indicators on for more than 15 seconds they stop illuminating and the relay starts clicking double quick, if i cancel them and reapply they are fine.
2) On the wiper side my intermittent works, as does my full on deluge, but the slower constant one does not, well it does if i waggle the stalk.
My hunch tells me this is a contact issue. And could be cured by taking stalks off and cleaning and fettling. Does anyone know otherwise?!
Hi Barnsey,
I suspect the indicator issue is down to a duff flasher unit. I'd agree with you on the wiper problem. I'm sure the more knowledgeable will be along soon.
Regards,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Flasher unit?
It's all controlled by the BSI now.
His is apparently a '99 so it will have a grey flasher relay.
Yep, sorry should have highlighted that, a 99 Multispace 1.9n/a power house!!!
Apologies. Confusedillyme:
I forgot they made Berlingos during the last millenium! :lol:
[-] The following 2 users say Thank You to j90xxx for this post:
  • addo, Barnesy
(29-12-2013, 07:52 PM)Barnesy Wrote:  Ok, I have a problem with my stalks:
if like said in other posts on a 99 plate then i dont think it will be fitted with a coms unit it will have separate stalks, is the horn on the end of the light stalk?
The horn is on the end of the light stalk.
Also I've realised when the indicator starts to run strangely, if I apply pressure the length of the stalk towards the steering wheel, it clears up, similarly the wipers too. All points to an electrical contact issue with the stalks to me.
I tend to agree with you.Hopefully it's just dirty contacts.:thumbsup:
(31-12-2013, 02:25 PM)Barnesy Wrote:  The horn is on the end of the light stalk.
you can pick up second hands indicators for them for about £5/10 as its not a comms unit they are separate stalks
[-] The following 2 users say Thank You to trustme for this post:
  • addo, Barnesy
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
