Threads: 10
Thanks Received: 7 in 5 posts
Thanks Given: 3
All bsi reset instruction seem to say that you need to use the locking remote ignition key as a part of the procedure. I acquired the vehicle with only two non remote keys. Is it still possible to carry out the reset without this key? Thanks.
Threads: 17
Thanks Received: 14 in 10 posts
Thanks Given: 6
Have you got a button on the LHS of the steering column cowl ? If so its the volumetric alarm disable.
If you press that while turning on the ignition, it should reset the BSI
'98 D 800 van
Threads: 4
Thanks Received: 1 in 1 posts
Thanks Given: 10
I don't have a button on the side of the steering column and I don't have a key fob either do I just use the lock button in the middle of the dash
