Threads: 37
Thanks Received: 38 in 37 posts
Thanks Given: 11
Hey guys, im stuck getting brake discs for my 2007 1.6hdi Berlingo. I know they are 266mm but there's two types of 266mm, ones with ESP and ones without any easy way to tell which ones i will need?
Threads: 67
Thanks Given: 237
50
Can you not use your registration number and or chassis number at the local motor factors to find out, they have all the catalogues to hand. Failing that an enquiry at the local dealership should provide the correct information.
Serieal Berlingo owner
Threads: 37
Thanks Given: 11
I only tried euro car parts they told me to measure the discs which i did and found out they are 266mm that's all they could help me with really.
Threads: 67
Thanks Given: 237
50
Oh well the shops are open tomorrow so you will get the info there soon enough and then you can trawl for the best prices, some significant savings can be made on routine service items like these and other things so don't buy over the first counter unless the world is about end and you want to escape it.
Threads: 51
Thanks Given: 23
I found with mine I had to measure not only the diameter but also the thickness and the height of the centre boss on the existing discs before I was able to buy from ECP with confidence. Their website listed about 4 different discs for my car. I also found that mine was the one without pad depth sensors and that made the final choice for me.
Malc
Stupid computer!
