  • 2 Vote(s) - 2.5 Average
[Engine] Glow Plug Pre Heat
Hi all,:wave:
I have tried to look if this has been covered, and I may have the answer- but just need to clarify.Confusedcratch:
My Lingo will NOT pre heat the plugs- no power to them, BUT once started it will Post heat the plugs for approx 45 seconds.
Would I be right in thinking this would lead me to a 'duff' relay in the control unit on the nearside inner wing?
Thanks in advance
Steve
Which engine do you have? What year? The turbo diesels generally don't activate heaters until the ambient temperature is around
freezing.
It's a 52 plate, non turbo. Its the 1.9
Also pulled plugs out- these all check fine, and offside 2 plugs were saturated with oil....... not black carbonised oil, but clean fresh oil??????
Any ideas?
(02-01-2014, 11:36 AM)Steve hicks Wrote:  Hi all,:wave:
Thanks in advance
Steve
I am also poking arround to try to get rid of my: "pre post heating relay circuit coherence" error. Although I have a 2.0 HDI engine, I measured the same, no heating until the engine has started, but for a few minutes. So, there might be no pre heating, but still post heating once the engine runs, but no one on this forum who can confirm this unfortunately.
The 1.9 non HDI needs pre heat to start.
My old un wont start from cold without them.
You need to check out the circuits/temperature input etc
(11-01-2014, 10:07 PM)obdtech Wrote:  The 1.9 non HDI needs pre heat to start.
My pre heat light never been seen on dash??? Blub gone maybe?
where is the temp sender located?
Leaking windscreen or aerial
Last Post: Guanajuato
Yesterday 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
