  • 3 Vote(s) - 1 Average
2002 1,6l electric fault!
Shocked
Hi everyone! I have A Berlingo 2002 1,6l. Fuel pump lost power to the fuse. Workshop has taken power from somewhere else. What Could be the fault of the power lost? After 3 weekend, does not stop the car Even if the ignition is turned off. Key removed completely. Anyone know where I can start to search? Where can I obtain better electric form than in the Haynes book?
Made with Google translatorBig Grin
If you can P/Mail me your Vin No. I'll see what I can dig out. :thumbsup:
Here's the diagram for your fuel pump (1211).
It is fed from fuse 25 In the engine fuse box (BM34) which is fed via the the double relay "1304".
This in turn is fed from main fuse 26/14.
Firstly check the connection from the pump to the main wiring loom as there are other posts about the connections rotting.
Check the collision cut off switch (1203).
This is a magnetic switch which cuts off the fuel on impact etc.
This should reset by pushing the rubber tit on top of it.
This is positioned on the bulkhead near the camshaft.
If still no joy then you are going to need a meter of some kind to measure the voltages through the circuit.
Of course you will have to put wiring back to original to test it.
Let us know what you find. :thumbsup:
  • vw1952
:woop: thank you Rustscrat. I have no bin out in -20 degrees. Have put in A new double relay "1304". And put wiring bak to orginal. It now works fineBig Grin
Excellent, thanks for letting us know.:thumbsup:
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
