  • 5 Vote(s) - 2.2 Average
6th gear, well nearly
I was out and about last night and at around 60mph went to put the car in 6th gear. I know there isn't one but my last vehicle did have and I slipped into blonde mode. I was just about to let the clutch out when I realised my mistake.
Why on earth is there no proper gate to prevent you doing this? If I'd let the clutch out I would have been looking for a new gearbox at the very least, scary or what?
Anyone else made this mistake?
Cheers
Ian
2012 Berlingo XTR 110 in Iron Grey
Money cannot buy you happiness but it far better to cry in Ferrari than on a bicycle
Haven't done it yet but have to keep reminding myself it only has five gears ,so used to six speed boxes.
Once or twice a year I grab the lighting stalk and attempt to put the car in first gear.
(03-01-2014, 08:02 PM)Bigian Wrote:  I was out and about last night and at around 60mph went to put the car in 6th gear. I know there isn't one but my last vehicle did have and I slipped into blonde mode. I was just about to let the clutch out when I realised my mistake.
I'm still in third at 60 :lol: Proper blonde would be if you opened the door to let the clutch out Confusedalut:
  • Bigian
My five speed van always feels like it ought to have that missing sixth gear!
So, to simply sum up…..
First I reach down for a second because fifth feels like fourth.
Sometimes this happens in reverse….
So I just go forth in fifth….. :eek:
Good judgement comes from experience, and experience comes from bad judgement…
2017 Berlingo Multispace Flair 120
2013 C5 Tourer 2.2HDi Excl
Previously:
2012 C5 Tourer 1.6HDi auto
2012 Berlingo Enterprise 1.6HDi Van
2009 C5 Tourer 2.0D
2001 C5 Tourer 2.0D
2001 Range Rover 4.6 Vogue (really!)
(03-01-2014, 08:02 PM)Bigian Wrote:  Why on earth is there no proper gate to prevent you doing this? If I'd let the clutch out I would have been looking for a new gearbox at the very least, scary or what?
There is no synchromesh on reverse so the crunch should stop you. On my mk2 car you have to push the lever hard across and back to select reverse. Is there something wrong with your linkage ? Last car we had was a Kia and the controls were back to front so every so often I flash my wipers at people and indicate to wash the screen Big Grin
Everything is fine with the box, only done 9000 miles but you can feed it into reverse at speed, scary stuff. I'm coming to terms with 5 gears now so hopefully no more scares
Surely it's impossible to engage reverse from 5th. anyway.
The layshaft is spinning in the wrong direction and if you tried
although you might get monumental crunching it would never mesh.
As already asked...Why doesn't the box on a Mk.3 have a gate.
It's not impossible as a couple of my customers proved.One had a huge hole in the gearbox case.Not cheap.Rolleyes
WoW!! :eek: A bit like the Daily Telegraph motoring correspondent who was test driving a new Jaguar sports
and managed to get that into reverse at over 150mph!! BANG!!! :whistle:
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
