rear nr side indicator not working, not the bulb
Thanks Received: 2 in 1 posts
Thanks Given: 2
Afternoon all,
this newbie would like to greet one and all and search for a solution to this problem: rear nr side indicator not working; have changed bulb, side indicator and front are working but are blinking twice as quickly as the off side trio: help please
JBA62
The following 2 users say Thank You to JBA62 for this post:2 users say Thank You to JBA62 for this post
• addo, Ol'Jeffers
Threads: 67
Thanks Given: 1,045
You'll need to probe the wire back. It runs under the scuff plate on the passenger front door, then up the left side of the dash into a cable tray.
• JBA62
Thanks Given: 2
(04-01-2014, 12:47 PM)addo Wrote: You'll need to probe the wire back. It runs under the scuff plate on the passenger front door, then up the left side of the dash into a cable tray.
thanks, sorry to be thick, not sure what t you mean by probing am I safe to assume, it is a broken wire ?
Threads: 67
Thanks Given: 1,045
Yes, get yourself one of the cheap piercing probe test lights with a proper bulb (not LED) in it. You should have change from a fiver.
Start at the bulb socket, make sure it isn't just a rubbish connection, then identify which wire it is in the brown multiway plug on the back of the light. Look for the numerical code painted on the wire, it may change colour over its length but the code will be the same. Find the same wire under the passenger door scuff plate (sill trim) and check it there - I'd suspect you have an issue between the A pillar and the rear wheelarch due to either a bad interconnect or corroded wiring.
• JBA62
Threads: 23
Thanks Given: 50
29
Hello JBA welcome to the forum
Thanks Received: 1 in 1 posts
Thanks Given: 1
did you ever fix the fault i have same problem on my 2013 berlingo
Threads: 43
Thanks Received: 414 in 371 posts
Thanks Given: 137
33
13-02-2024, 08:19 PM
(This post was last modified: 13-02-2024, 08:20 PM by brodfather11.)
Hes had over ten years to fix the fault , probably sold it on now.
Are the correct bulbs fitted . Some are offset pins but normal pin bulbs can be fitted/jammed in.
The hazard light switch can play up if its not used for a while , work the switch on and off a few times to clean the inside contacts.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thanks Given: 1
it was working fine i was indicating at a junction it was working fine and after about 1minute waiting to turn it just started going fast like a bulb had blown, so when i got home noticed the rear passenger side stopped working, i checked the bulb and stuck a multimeter on the bulb holder and no voltage, i took the brown 6 pin connector out the back stuck the probe onto the ground and pink indicator wire still no voltage, its just like its gave up the ghost, im currently half way pulling the trims and carpets up to locate the wire to test for continuitiy, going to pull wire from BSI and see if its continuous if not i need to locate where the fault has happened
Threads: 0
Thanks Given: 2
Did you get to the bottom of this problem, I have exactly the same symptoms. Fault codes suggest short to ground, but also some indication of issues with the other LH rear lights like short to positive. Would be good to know if you discovered a location for possible rear loom damage, or if BSI was at fault?
Threads: 46
Thanks Received: 153 in 123 posts
Thanks Given: 34
21
(14-09-2025, 07:12 PM)Rallychris Wrote: Did you get to the bottom of this problem, I have exactly the same symptoms. Fault codes suggest short to ground, but also some indication of issues with the other LH rear lights like short to positive. Would be good to know if you discovered a location for possible rear loom damage, or if BSI was at fault?
What year and model of Berlingo? Have you got any other faults apart from the LH rear lights?
_______________
Not a Citroen
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Rattling calipers
Last Post: Chrisfox1975
Yesterday 08:09 AM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
