09-06-2011, 01:55 PM
I think that I have bought a heap of junk :brickwall:
Just have a ton of work done for PSV
Rear axle mounts replaced
Track-rod end replaced
Bottom ball joint replaced
Nearly every bushen in the front replaced
Two rear wheel cylinders
Rear rubber brake hoses
Master cylinder replaced
New exhaust front to back
Two rear tyres because they were the wrong load rating and that was on top of me replacing the heater matrix with the lose of two litres of blood in the process never mind the the leaking aerial and leaking windscreen washer bottle :censored:
Now the fuel guage has given up the will to live :ill: anyone replaced one or might there be something else I can check before taking the fuel tank out?
At least it should be a good van if it ever passes PSV
Roly
2004 Berlingo 600 Enterprise
afesex: If in doubt flat out!!
afesex:
afesex:
