10-01-2014, 01:35 PM
I have a strange one here, to give you the whole story I had a few engine management error codes come up a while back relating to fuel management issues, posted some questions here:
http://www.berlingoforum.co.uk/showthrea...1#pid50701
I had these put out as I wanted to monitor which ones came back on as sometimes you get random faults, but they never did. Happy Days.
Next thing I noticed was the van had developed an oil like and when I went to investigate there was far too much oil in the sump. So I just assumed that I'd messed up at the last oil change as it was due a change again I did so and thought all was normal.
However recently checking the oil there was again too much in the sump and I let some out and have been closely monitoring it since, and sure enough it is filling up. But there is no other issues with the van, no loss of power and no fault codes.
I can only assume this extra volume is fuel as it definitely isn't coolant. I have been running the van on bio fuel for the last couple of years.
What do you think??
What do you think??
