  • 1 Vote(s) - 5 Average
Dash Display
Just been given a 56 plate Berlingo van at work with only 64k on the clock. Quite pleased with it overall but there is a problem with the dash display. I've looked at the handbook and followed the instructions but cannot set the time. Having had a little look on here about this problem, should I disconnect the battery and follow that route or is the display unit knackered. Any advice welcome.
Thanks,
Vince.
No need to disconnect the battery to adjust the clock!
You use buttons A & B on the face of the display.
Long press on A accesses the menu. Then short presses scroll through the menu.
Five presses scrolls through to hours and six presses gets minutes.
  • Vince
I was lucky enough to get the manual with the van and have tried doing it the way you describe OJ. No luck :justno: I'm thinking about the battery disconnection or I may just have to accept the display is broken. It is now stuck on German !!
Have u tried pushing both A and B at the same time for a few seconds? That might do the trick.
[-] The following 1 user says Thank You to Michel for this post:
  • Vince
Thank you Michael, I will try that.
Success !! Disconnected the clock today and left it for a few minutes. Then re-connected the plug and hey presto the buttons now work as they should. Thank you all for your advice, I appreciate it.
Vince.
[-] The following 2 users say Thank You to Vince for this post:
  • Ol'Jeffers, RolyG
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
