Thanks Received: 1 in 1 posts
2006 1.9D Mk2 White Van. Last June the battery was flat a couple of times after I had left it for 3 days. It had a new alternator so I guessed it was time to renew the battery. Then in August it was flat after being left for 3 days while we were camping. RAC tested battery and alternator all OK. It happened again in September after being left in its garage over the weekend. Now I disconnect it every night and think one day I will find out what is draining it. All original equipment, interior lights turned off, no phone charger etc. So any Berlingo experts seen this and know exactly where to look? thanks
Threads: 67
Thanks Given: 1,045
You may have an alternator problem.
Easiest (joke!) test is to disconnect the alternator when the car is to be stood for a few days. If the battery holds charge then the AA were wrong.
Threads: 3
Thanks Received: 4 in 2 posts
Thanks Given: 2
11-01-2014, 10:41 PM
(This post was last modified: 11-01-2014, 10:44 PM by obdtech.)
Make sure battery is fully charged on a decent smart charger then tested.
If its low on charge, starting is marginal/no reserve.
If a battery goes flat it needs charging fully with a charger.
Test drain with amp meter.
Threads: 20
Thanks Given: 2,126
18
I charge my battery every month for 24hrs.Never had a battery problem/new battery.:thumbsup:
Strawberry flavoured windows
Threads: 20
Thanks Given: 2,126
18
My thoughts precisely.:thumbsup:
Thanks Given: 1
16-01-2014, 10:41 AM
(This post was last modified: 16-01-2014, 10:41 AM by chrisbis.)
Hi chaps.
I have just bought a Berlingo Van Mk2 04 plate, and the battery is run down (I won't use the word flat, as that is reserved for tyres and place of dwelling! lol)
I do not know (at this time) what the radio code is, and i wondered if I can charge the battery whilst still connected to the van, removing the cells caps for venting, and therefore avoid the coding issue on the radio.
I also have a strange noise that comes from the behind the steering wheel/fuse box area, like a solenoid whacking back and forth, after I open any door.
Is this a door central locking sol opening & closing because its faulty, of something else?
The back door lock is seized and I have disconnected the link connector to the door mechanism/actuator, but I wonder whether I need put a temp link in the loom/connector to show the computer that the door is shut?
Maybe its one of the other doors actuators that is faulty?
The noise happens every time I open one of the two doors (front)
Central locking will not close at this time.
The battery post above was most helpful...thanx.
Threads: 42
Thanks Received: 408 in 365 posts
Thanks Given: 137
31
You can charge the battery in situ, don't need to go removing the cell caps for venting as it will be a sealed for life one. They can be removed but as the smart charger will not allow the battery to start fuming or overheating there's no need.
It may be a broken wire in the door jambs that is causing the locks to go awry.
