Threads: 15
Thanks Received: 2 in 2 posts
Thanks Given: 1
Does anyone know how much antifreeze I should put in the van and does it need bleeding once I re fill it up .thanks
Threads: 67
Thanks Given: 1,045
I mix it one third by volume, you must bleed up the system with engine at cold idle - look for bleed points where the heater hoses enter your bulkhead, also a 5mm internal hex head bleed screw near the thermostat housing (do not overtighten!) and at the top of your left side radiator header tank (usually).
Stop bleeding when the flow is free of noticeable air bubbles, working from the lowest bleed screw to the highest. Keep the header tank topped up as you do this. Rinse off spilled coolant immediately with warm water and a little proper car washing detergent in solution.
Threads: 9
Thanks Given: 316
15
yes 50/50 as antifreeze contains a corrosion inhibitor but needs 50% to work.
Drain and flush the system with fresh water - find the total coolant capacity and halve it - ad neat antifreeze to 50% and top up with water - bleed system bingo
Threads: 67
Thanks Given: 1,045
The one I use here, states on their own label that it's OK to use at 1/3 by proportion. It's an old school ethylene glycol type.
Threads: 3
Thanks Received: 4 in 2 posts
Thanks Given: 2
50% also allows tolerance to the odd water top up
