I broke the left rear side window, how do you change it? It has a moulding like hinge that seems to be bolted or screwed on chassis. The bolts seem impossible to reach. Has anyone a hint?
Threads: 28
Thanks Received: 13 in 13 posts
Thanks Given: 7
they are held on with 3 little torx screw, i removed mine easy enough when tinting the windows.
MK1 Berlingo, Y-Reg 1.4 Petrol Now LPG Converted.
I mean the last window at the back at left hand side. The screws are inside the pillar.
Threads: 28
Thanks Given: 7
the glass is held in via 3 plastic hinge (for want of a better word), just remove the 3 torx screws and remove the glass only, leaving the "hinge" in place
