  • 5 Vote(s) - 3 Average
Bsi Water damaged, Changing questions?
Hello
sorry to bother with this post
iv currently got a friends 2003 mk2 berlingo van and it had a water leak from the window which damaged the bsi, weve changed the bsi to a model from a similar vehicle
the lights and dash still remain illuminate and ac t strangely
the bsi code is
bsi e01-00 hg
i do have pp2000 and lexia and was wondering if i could code the the new bsi from the previous one and if anyone has any experience?
also if anyone has any knowledge on how to successfully change the bsi to another one, the bsi weve changed to does have the same model number it is second hand but from the same model
if anyone has any suggestions, on how to go about doing it correctly
regards
save coding from old one(if still works?) or swap eeprom?
To reuse S/H BSI it needs to be virginised (effectively wiping data to 'as new')
Fit new & change coding/vin no. program keys with pin no.
Check everything works Smile
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
