  • 2 Vote(s) - 1.5 Average
side lights !!!!!
Hi Everybody
I have a 51 reg 1.9 diesel (non turbo) 600 van
I need a bit of help
when i put side lights on the brake light come on as well !!
plus when i put the brakes on the side light comes on !!
I have cleaned up the earths on the rear lights but it is still the same
Have any of you ant ideas ?
thanks
Have you checked that the lamps are the correct way round in the lamp holders as these have offset pins. :thumbsup:
i have a similar problem I have side light front and rear also a fog light that stays on even when ignition is off I have to disconnect the bateerry every time iu have had some check the earths but they all ok
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
