  • 2 Vote(s) - 4.5 Average
Really daft first question! Give me light!
Hi, new to the forum.
I've got a '99 van that has a courtesy light in the back which comes on when you open the front doors along with the usual front one. Citroen didn't think to fit a pin switch on the rear door so I have to turn it on manually but that's a bit silly when it's dark!
I know the later models have a pin switch in the rear door shut to allow automatic operation, so I got a new switch to use.
However when I unclipped the rear courtesy light unit there is about 5 or 6 wires connected to the bulb holder!
Might seem a really daft question, but which wire do I need to take to the pin switch?
Thanks in advance.
Richard.
[-] The following 2 users say Thank You to breadman for this post:
  • addo, CandR
I'm very interested in this tweak. If you can, please show a few pictures as you sort it out.
'Ages since I've been on here, but just a quick update for those interested.
If you unclip the plastic vent in the o/s rear door shut you'll see a cream coloured wire with its plug taped to the loom. Undo the tape to free the wire then simply drill the holes for the pin switch and connect.
Bingo! Rear door operated courtesy light!
I've gone one better and fitted another light unit on the opposite side to mirror the original. I took a paper rubbing of the existing light hole, cut it out and then drew round it. It takes a bit of careful cutting with a slitting disc in a grinder and some filing to create the correct size opening with radiused corners for the light surround to fit, which the light then clips into. I managed to get a section of wiring loom from the same van I got the light from so it was plug and play at the light end but I made a soldered and heat shrinked loom extension to the existing light side loom. I hid the extension loom in the body frame over the rear door opening. It looks totally factory and with LED bulbs it really lights up the load area.
Well chuffed with it!
  • brajomobil, ron
(20-02-2015, 12:08 AM)breadman Wrote:  'Ages since I've been on here, but just a quick update for those interested.
Thanks for the info,it's these articles that make the forum interesting. Smile
Rear seat belt breakage
Last Post: Mad one
Yesterday 06:09 PM
Yesterday 05:49 AM
11-09-2026 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
