  • 3 Vote(s) - 2.67 Average
delayed igniyion pre heat
hi fellow Berlingo ers, I have resently developed a pre heat delay problem, with a twist! When the ignition is turned on the digital display is very very slow. The "spanner/ sevice interval", then "temperature" then "clock and current mileage" at which point the glow plug symbol comes on then goes out, is now suddenly taking 16 seconds! whereas before it was taking about 5 or 6. I have cleaned and checked the earths, battery to engine and bonnet to body shell. Please, any ideas or suggestions, thanx
[-] The following 2 users say Thank You to kf onti for this post:
  • addo, Ol'Jeffers
Hola y bienvenidos al foro. Which year and motor do you have??
Hello kf onti welcome to the forum
Hi and welcome!! It is important to tell us which model and the year as there are
a few different Berlingos! This sounds like a bad earth somewhere!
(20-01-2014, 10:35 AM)3rensho Wrote:  Hola y bienvenidos al foro. Which year and motor do you have??
sunny good morning, my berlingo is a 2000 model 1.9 deisel. the problem almosts seems like the electric supply is struggeling and is delaying somehow. thanks
(22-01-2014, 01:31 PM)OlJeffers Wrote:  Hi and welcome!! It is important to tell us which model and the year as there are
hi and thanks, i ve checked and cleaned the 2 earths i can find, body to bonnet near the hinge and the battery negative terminal, are there any more? i only disconnected, cleaned contact areas, should i lightly grease these areas too to optimise the conntact points? thanks
ASDA AdBlue 10 January 2026
Yesterday 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
