Threads: 50
Thanks Given: 743
Over the last couple of years I've noticed that some very naughty people
haven't put their Berlingo model in their profile so it shows on the forum. :p
When they want help, quite often, they still don't tell us. You can put it in the signature if you want!! It would help. :thumbsup:
Threads: 67
Thanks Given: 1,045
I love guessing games!
Maybe we need a standard response for all such under-informed questions? "Muffler bearings"...
Threads: 23
Thanks Given: 46
5
In the days that I worked the mechanics standard answer to vague questions was that "The giggling pin has fallen off the laughing shaft"
Threads: 67
Thanks Given: 1,045
Absolutely. But if people are a bit squeezed for cash, ECP sell a rebuilding kit with new bearings and a tube of muffler putty. You need to reuse the sparks.
Threads: 67
Thanks Given: 1,045
Either is OK, they self-polarise once the bearings are spinning.
Threads: 20
Thanks Given: 2,126
18
Thanks,Addo.I would hate to misuse them & get a short.:thumbsup:
Strawberry flavoured windows
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
If the problem sounds like the suspension, tell them that they need to bleed the High Pressure reservoir and check that the hydraulic Return lines don't have any signs of leaking.
If the problem is motor related, Write that it's quite common for turbines to be a bit rough if there's traces of water in the JP fuel, and that the problem will sort itself out the next time they refuel.
For anything else, Write that they have a BallX occlusion.
(Cloudy Crystal ball... )
