  • 2 Vote(s) - 2.5 Average
We got bills... (Things you might want to check)
Put the Berlingo in for brake fluid and pads change and asked my mechanic to check it over thoroughly as I'll likely have a 2000 mile road trip in the summer with a trailer.
It is a 1.9D 54 plate and has done 124500 miles so I thought it might be worth sharing the findings so others can check to see if their Berlingo needs the same.
- Radiator bulging at the side - replaced
- Master cylinder worn (He could not get the brakes to breed properly) - To be replaced on Monday, no time to source and fit on a Friday
- Both rear brake cylinders slightly leaking - replaced
- Ball joints worn (I could hear knocking) - replaced
So if yours is of a similar age/mileage it may be worth checking these items.
I don't mind as apart from regular servicing it's needed NOTHING else since I bought it in November 2011. I'm glad these items were identified in time to fix!
On Thursday I was lucky(!) enough to get a screw through the side wall of a year old tyre on the back, another £64 I could have done without spending...still had 6mm tread on it Sad
2004 1.9D Multispace/Budget crew cab work van!
Useful for general wear and tear issues to keep in mind, cheers
Sent via Mobile
Let's hope that's your last big spend for a while.Scrapping a tyre with 6mm would reduce me to tears & looking for a crowbar to open my wallet.:brickwall::whistle:
  • chronyx
(25-01-2014, 09:49 PM)ron Wrote:  Let's hope that's your last big spend for a while.Scrapping a tyre with 6mm would reduce me to tears & looking for a crowbar to open my wallet.:brickwall::whistle:
I certainly wasn't happy Big Grin
My radiator went a month or two back. Bulging at the side just like yours. I got one from ECP or Carparts4less for £50 or so. Fortunately they're a doddle to change on these cars, less than an hours work.
Malc
Stupid computer!
M59 1.4 Petrol question
Today 08:47 AM
Today 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
Yesterday 06:47 PM
Last Post: deejay_xb
Yesterday 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
Yesterday 01:48 PM
Unusual Braking Problem
Yesterday 07:52 AM
valeo alternator CL15 rebuild
Yesterday 07:49 AM
15-03-2025 06:19 PM
oil Sump
15-03-2025 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
15-03-2025 04:34 PM
