  • 4 Vote(s) - 3.25 Average
No turn over
On Monday I went out to my berlingo 2.0 hdi Multispace '04 that turned over twice and then stopped? I have since charged the battery and checked all fuses etc and yet the vehicle still wont turn over?
All dash lights come on as normal and all other electrics work.
Is there any known faults that I should be aware of such as relays, fuses etc that are located somewhere that you cant see?
Does the starter attempt to turn ? .
If it dosent then suspect battery connections to solenoid ,earth straps to chassis, starter motor ,
Check fuses in engine fuse box and the solenoid is getting a signal from the ignition switch when turned. (Need a test lamp or multimeter to check)
May just be a duff starter motor , try hitting it with a hammer gently while someone else is holding the key in start position
If starter is trying to turn then suspect engine not allowing it to turn it. eg broken timing belt/camshaft/valves.
(28-01-2014, 05:32 PM)brodfather11 Wrote:  Does the starter attempt to turn ? .
The Starter motor doesn't turn at all. when I put the ignition on I can here the relay click but nothing cranks? I haven't had any signs of a possible faulty starter motor?
Have you tried brodfathers' suggestions?Confusedcratch: It's no good asking for advice if you ignore it.
Hi tinks3010,
I had the same problem, I was told if the car will bump start and runs it is the starter motor. Mine did start from a bump start so I changed the starter motor and all was solved. May be worth a try
[-] The following 1 user says Thank You to Rabbit73 for this post:
  • RolyG
So I took your advice brodfather and whacked the starter motor whilst having someone turning the key in which the starter motor did try and move. I changed the starter motor last night and all is working well.
Thanks for all your help
[-] The following 1 user says Thank You to tinks3010 for this post:
  • RolyG
Great; always good to pinpoint the cause first time.
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
