Threads: 6
Thanks Received: 2 in 2 posts
Thanks Given: 3
30-01-2014, 03:41 PM
(This post was last modified: 30-01-2014, 03:43 PM by Grem.)
Hi,
I have an XTR on a 59 plate and have been having strange goings on for about the last 6 months. Intermittently the radio has begun to play, when I have unlocked the car. Then the other day, after I had unlocked the car and been in the boot, searching for a lost glove, I opened the front passenger door. As I did this the wipers started. They worked for about 30 seconds then stopped, in the up position. I checked the wiper switch and I thought it was in the off position. When I later started the engine the wipers didn't come on and the switch was definitely off.
Another weird thing is that sometimes the radio will work, with the ignition off, for 30 minutes, other times 30 seconds and it goes to economy mode.
Any clues?:
Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
an exorcism needed I think :twisted:
:woop:
:whistle:
Threads: 29
Thanks Given: 67
20
Is it on finance, it sounds like it's about to be re-possessed
The following 1 user says Thank You to ffrenchie for this post:1 user says Thank You to ffrenchie for this post
• addo
Threads: 20
Thanks Given: 2,126
18
I was worried reading the title of your post.I thought you were referring to us members!:whistle:
Strawberry flavoured windows
Threads: 23
Thanks Given: 50
29
Hello Grem the radio will stay on longer the more time you've been driving before going in to eco mode
As for the other thing's it's getting a power feed signal or short or maybe a bad earth
Threads: 23
Thanks Given: 50
29
The best thing to do is to look at you wiring follow it as far as you can look for fraying check earth points the other thing is with all this rain is water ingress so look for that as well
Threads: 6
Thanks Given: 3
Thank you Jed,
I'll do that at the weekend, if its dry enough.
Threads: 3
Thanks Received: 5 in 5 posts
Thanks Given: 1
Hi
On my van if you turn off ignition switch then press the stereo power button it will run for thirty minutes.
As jed said a bad "earth" or negative feed can cause odd things.
Try the door light switches, see if they are clean and tight.
The other point to bear in mind is so much on modern vehicles goes through the ecu , even a little resistance caused by corrosion will trigger components.
Jon
